After I changed my spring to the Baisley (I used the LMR-002), my oil pressure was a bit high for a few thousand miles. Would be up near 60 psi on cold starts, then fall to about 38-45 after warm up with about 20 at idle. Now, with over 15k miles on the spring, it is in the high 40s low 50s at cold start and around 32-35 at highway speed when warmed up. Idle is around 10 or so once warm.
Very satisfied with this mod.
I have to ask, why are you changing the oil pressure...is it because of higher altitude, Stage X mods or some symptom or characteristic with your model/year?:eam
