Hope you got your problem solved, but based on what you said in entry point #4, it is hard to believe a plugged IAC was the problem. (Or maybe I am reading too deep into the reply)
Giving the engine throttle with the grip (as said in entry point #4) supplies more air than the IAC will ever supply & the engine should have picked right back up but that did not happen. If the engine still dies even with attempts of giving it throttle by twisting the grip, it's not an IAC problem.
Yes, a plugged IAC will not let the engine idle on it's own, but using your hand grip will enable you to keep it running. Sounds like that was not the case(?)
Heres a list of everything we did this weekend. (My brother and I)
Installed new fuel filter and fuel line, inside the tank.
Installed new crank position senser
Topped of water in two month old battery.
Charged battary.
Tested battery. (good)
Tested charging system. (good)
Cleaned air filter.
Added small amount of octane booster to fresh tank of gas.
checked, wiggled almost every wire on the bike.
Ran speedo diag, found code PO118.
Cleared code, did not reappear.
Spreyed carb cleaner in IAC port, large amount of black gunk dislodged.
Sat on the side of the road approx two hrs.
Started running good after the carb cleaner.
I'll leave it to the guru's as to what may have caused the cure. All I know for sure is, Im riding again and am one (EDIT) happy camper !!!
Thanks again one and all...
