kabory
So are you pretty happy with it ? I just ordered the same one the reviews was great. Did you try adjust the front of the braket?
Its ok, the tire plates were a liitle sloppy, I added more washers to tighten the gaps. The rear plate is wide and I believe thats where the problem is. A wider tire like on a fat boy would work perfect. Got the straps working good now with minimal fork compression. Thanks for everyones input.
On another note, I had to bolt the chock down to my garage floor. Without bolting it down, it just skates across the floor before the tire gets in.
