Sounds like you may have solved it. Another way I check for Ign./fire failure is to let it idle on the 1 cylinder for a minute or so then take a squirt bottle with water & squirt each exh. pipe. The running one will Sizzle the water, the misfire one will not Sizzle the water. That way you know which cylinder is bad. On a single fire system with 1 coil it won't help to rotate the plug wires because the they will be 180* out time for their sequence due to control module.
tourbox
P.S. Welcome from So. Texas.
tourbox
