I haven't a clue why the torx screws came loose? The screw heads are below the level of the windings. There is no damage to the windings. The screws appear to have been removed and replaced at one time because the one screw that was just about to loosen didn't have any loctite on the threads. That's a big mistake not to use red loctite. It appears that vibration of the stator on those loose screws caused them to shear. I can't think of any other reason other than the past owner didn't properly re-install the rotor in the past using loctite. I've only had this bike since August, 2010 and have put on 10,000 miles since then. This is my first Harley. Everything to date has been a "Learning Experience."
