J
Jack Klarich
Guest
In a pinch if you dont have the right size allen wrench, you can find a bolt that fits the allen heat and bend it or take that same bolt and double nut it, it will work in a pinch, Capital Jack:s
Although I haven't figured it out yet I think I might have to make a tool here soon. I will be installing a set of chrome rocker covers. The manual calls for the use of two torque adapters to be used when installing the covers with the engine still mounted in the frame. The tools from snap on run $30 each! This is a tool I will use once and that's it. I am trying to come up with a creative solution to my problem and began thinking about making a torque adapter from an old standard wrench and a socket. I figured I could weld a socket onto the wrench to create the offset I need. The problem I have is the box end of the wrench has the angle on it. I might have to heat it up and bend it to make it flat. Has anybody ever tried to make a torque adapter in this fasion or should I just bite the bullet and put out the $60 bucks? If I were a professional mechanic I would definately buy the correct tool but it seems silly for somebody like myself. Anybody have any suggestions?
What I did is ground down a 7/16 & 1/2" sockets to fit a 7/16 open/box end wrench. My torque wrench will fit the box end. The book says to keep the 2 wrenches at 90* to cancel out the torque multiplier effect.
Keeping them at 90* will minimize, but not eliminate the torque multiplier effect. The effective length of the torque wrench becomes the diagonal between the center of the handle and the socket. Assuming a 15" torque wrench and a 6" combination wrench, the torque multiplier will be approximately 1.08 at 90*, much better than the 1.4 it would be if left straight.
What you are saying is torque multiplier effect @ 90* isn't enough to worry about as long as they are all torqued to the same value? I try to stay in the middle of the torque range given it the book. You say do the math...what is the math? Do you have some kind of formula you could share?
