Just like you Doc, when I did mine, the biggest difference was the engine temp followed by the upper RPM performance.
Doc,
Throttle by wire does have some "Throttle Progressivity" which does limit how much the butterfly will open vs the grip. This is what you may be feeling. (? maybe).
Once 2500 RPM is reached, the ratio between grip and butterfly is 1:1 (just like cable drive)
But if you are at 2000 RPM with the twist grip at 100% open, the butterfly is only 69% open.
Even worse at 1750 RPM, a grip of 100% only yields a 54% butterfly.
I have the complete chart if you want it posted.
Hoop,
That is what I was referring to in post #12. I'm just not smart enough to understand it![]()
Well, hopefully this thread will enlighten folks and keep them from getting unrealistically high expectations about the performance part of the Stage I upgrade.
Your cams are chain driven.Thanks everyone - I was afraid I was the only one that wasn't 100% thrilled with Stage I results. I'm glad I did it mainly for the cooler running engine and the better sound.
I'm not a fan of the 2 into 1 look on a bagger so that's not an option for me. I'll have to consider the headers vs. cams issue - thanks Hobbit. Don't get me wrong, I love my bike and I'm very happy with how it rides right now. I'm not looking to enter any drag races anytime soon!
Just doing the cams on a 2008 bike shouldn't be that big a deal, right? I watched TQ's slide show on his engine build so that gives me some confidence.
Do the 2008 TC's have roller chain or gear driven cams?
