No problem at all. Hope it sounds better than you expected.:s
Hey buddy since the stock horn had 2 stakes 1 hot the other was the ground. So no need for to go to the relay would it, cause wouldn't be the same as gronding the horn to the frame or does that have something to do with the horn button or relay. I just little confused that's all. lol The horn works so guess everything is fine. Yes the horn only has one stake which is the power.
thanks again
If the replacement horn is drawing more power than the stock horn you may overload the wiring/horn button causing electrical melt down
The relay is used to keep the amount of watts going through the handlebar wiring and switch to a minimum
the original wiring is suitable as a trigger for a relay
a relay is an electronically operated switch that can handle higher loads than the handlebar button
I would suggest that you do not use the horn till it is wired safely an electrical fire on your bike can spoil a nice ride
