Thanks for that sir, those are the pressures listed in the operators manual for my bike though.
The operators' manual or the sticker on your bike is a good starting point for recommended tire pressures for the stock OEM Dunlops. That will change slightly depending on if you change type or sizing, in which case you will guage the tread depth for even wear across the tread thru experience and manufacturer recommendations.
Case in point, Metzlers which I ran recommended 4 PSI higher in front and rear...and with my experience it worked out fine...even tread wear across the tread face. And no handling problem when I would take bike into the canyons or the super slab two-up. JMHO
