I didn't think I had to add that!:newsmile100:
You and I and some others know that but if there isn't a background in electricity, it's not so obvious :s
Make sure when doing the above that the clip is on the POS terminal, not ground.
You use a POS feed when testing for ground and a ground when testing for Battery with the test light.
Equally, make sure theres no fuel vapour about.
Equally important and don't forget the hydrogen gas near the battery with sparks too.
I am a bit confuse about were you have the sending unit mounted.
That looks like the adapter for an oil cooler and the radiator has been removed.
If thats the case it could be the problem. The only time I have even seen them mounted in the oil line the entire unit was there.
Other wise They were always in the oil pan ??
I have a PDF file thats shows what I mean if you want it
Doc, did you remove the tape on the sending unit threads?
