OK. Stymied!! One of the long bolts at the front of the primary that is screwed through the primary cover, inner primary and into the engine block WILL NOT come out without at least loosening the left hand floorboard mount. This is the mount that the jiffy stand is fastened to, and the front shifter assembly.
Does anyone know what size these Torx fasteners are? They are bigger than T-40!!! So once again, HDs engineering has made it impossible to do a 30 minute job in 30 minutes. To remove the Primary Cover, I have to loosen the floorboard support structure!!! Urgh!
Cheers,
