Breeze3at
Experienced Member
I'm giving this a go, and I've got the jack lift pads as far to the rear of the bike as I can get them. I can't take the lift pads any further towards the rear, as there is a cross-brace welded onto the frame tubing on the rear underside.
I'm jacking the ole boy up, and the front wheel is 6" off the ground, and the rear wheel is still grounded. I'm not liking the looks of this, so doing a check with the authorities here, as to if this is normal. Doesn't look normal to me.
The brace is about 3/8" below the plane of the underside tubing, and my lift pads are too wide to get in between the side ridges of this brace. So I can't position the lift any further back. Suggestion please...thanks
My '07 has the same cross brace. I put one of the jack rails in the brace, it's not wide enough, and chews the rubber up some. You could use a 1x2 piece of wood to shim the brace. My front wheel is at least 6" off the ground before the rear clears. If I move my jack in front of the brace, the front is too heavy, and I don't like the way it tilts the jack. It's kinda unnerving the first few times you do it.
