The site i use for parts has most of the parts lists for this century under their original parts search here
VAT Free Harley Davidson Parts - Jersey Harley-Davidson
To replace the mainshaft oil seal you will have to pull the bearing inner race from the mainshaft special tools are required to remove and install the inner race but if care is taken the inner race can be re used
when the inner race is removed you will get access to the oil seal that sits between the mainshaft and and the main drive
to remove the oil seal drill a small hole in the metal part of the seal about halfway between the inner and outer part of the seal centre punch where you are going to drill as your drill will be at a fair angle due to the mainshaft being in the way so drill bit would skip toward the mainshaft
insert a self tapping screw in the hole you have drilled and pull on the screw to get the seal out i use the claw end of a crowbar and it just popped out
clean up the area on the mainshaft where the seal bears as dirt seems to collect there
i used a a bit of abs pipe of the correct diameter to fit over the mainshaft and drive the new seal into place
i hope this helps
i hope this helps
