Caper
Finally got the fueler installed, the needle nose pliers and screwdriver was a great tip, thanks glider.
It almost seemed to be too easy....I set the low range RPM pot to 1800 and was going to set the high range crossover at 4000RPM but turned fully back it didn't crossover until 4500RPM so I left it in the 12o'clock position.(Instructions said 12o'clock would be at 3000RPM)
Except for the low range pot I find it is quite similar to the TFI so I have a little tuning question.
When I was adjusting the fuel for the ranges I set the engine to run at 1500 rpm in the low range then turned the pot until the engines RPM's increased then fell off, then i backed off then went up again until it reached highest RPM by adding fuel then back off the pot a tiny bit and left it there, did the same for the mid range but set engine to rev at 3000RPM. I didn't get a chance to test the high range since it doesn't come on untill 4500 so i just set that one at 3'oclock for now. A quick shot on the throttle and it popped with the accelerator pot at 12 so I turned it to 1 oclock and no popping so I left it there..
My question is.... is that the way to set the fuel pots....get the highest RPM and turn it back a hair??
The bike is running good ...no decel popping at all now and no pop or hesitation on rapid acceleration.
