I was reading this topic and went to Amsoils own site where it explains the different gear set types: ie - hypoid, helical etc and found the following statement:
" Most manual transmissions have helical gears and do not require GL-5 performance ". To my knowledge the new 6 speeds have helical gear sets. Wrong or right?
I do know from previous experience if a tranny has syncros in it and you put a GL5 spec verses a GL4 spec oil, it will get very hard to shift with the GL5 gear oil and it will destroy the syncros.
Being somewhat a logical person - If our HD 6 speeds don't have any yellow metal or syncros then you can use a sync GL5 spec, most likely a 75-90 as that is the same viscosity as a 20-50 sync mc oil ( which seems to be the factory viscosity recommendation ) without incurring any real problems. That most likely explains why you can use either the GL5 gear oil or the 20-50 sync mc oil without any wear issues. ( Drain plugs of bikes using either report little or no fuzz on magnets ) The original question about the yellow metals hasn't been answered. Somebody who's torn down one of these tranny's should have the answer.
