HOLY DIVER
Junior Member
There is no requirement to change the cams since you are going with the SE kit, and you are happy with the performance of the original cams. With the Andrews kit, or buying a kit with the plate that has the cam shafts run in a journal bearing, the cams have to be changed.
With those kits that have the cams running in bearings pressed in the plate, you can reuse the original cams if you so desire. You may want to consider changing out the sprockets on the cams to roller chain sprockets and use a roller chain on the inside of the plate. If not, it is probably a good idea to replace the silent chain if the original cams with the original sprockets are used. Definitely install new bearings in the new plate if it doesn't come that way.
Unfortunately, it seems that John (Herko) is no longer putting kits together. This is a big shame. His kit was very well thought out, and with the optional stuff he offered, it was a one-stop-shop!!
no more HERKO kits???? this is not good news for twincam88 owners.
