doctordoug
Account Removed
Sears jack is well made I have pulled many a tire off front and rear. Even strap free. It already has hook
Loops you should be fine
If you want a really good one pit bull is top notch.
Sent from my iPhone using Tapatalk
I second your feeling on the Pit Bull jack. I also have one and I never worry about the stability of my Deluxe when it is up in the air. The frame protectors are to me a waste of time. On most jack supports you can glue on rubbers pads about 1/4" thick where the frame contacts the jack rails and this will provide clearance for the frame rails. You need to have 4 pieces and leave a space between them for the shock clearance. What I did was position my jack where I wanted and then marked the frame rail position with tape, lower the jack and then glue on the 4 - 1/4" rubber pads each about 2" long. Works great and you don't need to put on and take off the frame protectors which is a pain. Good luck.:small3d026:
