Taildraggerdave
Tighten the jiffy stand bolt. Mine loosens over time and I find if I torque it up even a little it removes some of the movement.
I took it apart last night to inspect. Bolt was tight. Found some play in the square drive on the stand and the lock plate. Didn't see any abnormal wear on the lock plate sides or the sides of the bracket.
I thinks it's a case of tolerance stacking... A little play here and a little play there all add up to a lot of play when the stand is down causing the "heart attack"
Take care,
Dave
