I've installed the Kickstand Kaddy and while it hasn't had many hours of a road test my initial reaction to it is favorable. It's a piece of cake to install. Even one so wrenchly challenged as I am easily had it in place in just a few minutes. Just measure back from the pivot point on your jiffy stand and bolt the clamp around the tubular frame at that point. Don't tighten it up completely to start with because you'll end up rotating it one way or the other until you get the clip perfectly aligned for the jiffy stand to snap into place into the clip. I didn't even use tne lift; just measured the distance, bolted it on, and "cut-and-tried" to get the clip perfectly aligned and tighten the bolt.
I was going to keep it in my saddlebags for use if my jiffy spring ever went South again while on the road, but I like it and am going to keep it on even if I do feel kinda like it's overkill as long as your spring is tight...(kinda like wearing both a belt and suspenders for your trousers). Don't expect a heavy duty machined steel part, but for under $20.00 I think it's well worth the money.
