I still have the primary cover off. How much thread of the rod should be exposed? There is approx 2" of total thread. About 1.25 " is exposed. Should I screw more of the thread in? I should have taken more detailed pictures during tear down.
I suggest following Bubbie's procedure above, or any of the other ones found here:
Transmission,Clutch and Primary (Drive Train) - Harley Davidson Community
Basically, I do it like Bubbie said:
- Collapse clutch cable sheath adjuster
- Back off adjuster lock nut
- Turn adjuster screw in using forefinger and thumb only on allen wrench
- Back off adjuster screw 1/2 turn from finger "tight" (you can see the lock plate move slightly)
- Tighten up the lock nut making sure not to disturb the position of the adjuster
- Adjust the clutch cable sheath until the lever has about 1/4" of play
- Close everything up and back it out!!
