Speak for yourself Bud!
my bad:small3d007:
Tip the mower up and look under the cutting deck in the bottom of the engine. I never saw a small engine that didn't have a plug under there to drain the oil. Some are a hex head and others are a 3/8" plug that you use an extension on a ratchet to remove.
You could always try the small, hand operated oil pumps that you can get to pump the oil out of marine engines.
