doctordoug
Account Removed
This is just what Lenale did in my case
Smitty, do you run an oil cooler in addition to the Lenale? I think I will add both to my Softail.:bigsmiley23:
Hi Len, Was wondering if you would tell us a little about the motor that is used in your HD cooling fan. Are the bearings used, oilite, bronze sleeve or ball. Does the motor use carbon brushes and a commutator. Is it thermal protected in any way and what is the typical life expectancy in hours?
Tks Hoople!
************************************************Hoop and Bubbie you might get a faster response going thru Lenale's direct email, since I know from past experience he many times only answers this forum when someone notifies him of a question post. I.e. he doesn't read the forum that often. He has his own engineering company and is an Engineer.
Try this email,
lenale_engineering@comcast.net
Please share answers back with us.
RWB,
My problems came from the supplier I bought it from they did not stand by it . But once Lenale found out about the problem they took care of it right away 100% in my case. The replacement has work just fine and is going on the new 2011 .
I can not say how one would work for others I am ok with mine.
