Hi, i have a FXRS-C 1993, question is what is the small manifold that connects the front forks, it has a valve in the end of a small hose that looks like a tyre valve.
Is this standard and if so is there a certain pressure you run
Lurchy
That's the anti dive solenoid that closes when you apply the brakes to trap the air in the forks to prevent excess nose dive because of the extra air in the bars.
You should hear a faint click from the solenoid when applying the brake. It doesn't require a lot of pressure, usually less than 10-15 Lbs but check into it before you do any damage with too much pressure.
It's standard on the FXR line you have.
