if your codes are 1511 and 2135, chances are the 2135 caused the 1511.
2135 has a 33 priority while the 1511 has 77 priority.
2135 is Throttle position correlation error, as has been stated this can be caused by bad connections (including wires).
There is some testing that needs to be done on your part and post back the results.
Take the outer fairing off and locate the 6pin connector that connects to the twist grip connector.
there are 6 wires,
black/gray = 5v sensor ground2
violet/yellow = twist grip sensor 2
red/white = 5v sensor power2
black/white = 5v sensor ground 1 -- this same wire goes to pin 1 on the connector behind the air cleaner base
blue/brown = twist grip sensor 1
brown/orange = 5v sensor power 1 -- this same wire goes to pin 5 on the connector behind the air cleaner base
these two throttle position sensors work opposite from each other.
As throttle is opened, sensor 1 goes from 0volts to 5 volts while sensor 2 goes from 5v to 0volts.
at all times the sum of these two voltages must add up to aprox 5volts.
If they do not, the ecm can put into limp.
take your volt meter ( with ign on NO START) check red/white and check for 5volts (this 5v comes from pin 68 of the ECM.
I believe (its been a little while) if you also check brown/orange you should find 5v also ( comes from pin 50 of ECM)
put meter on violet/yellow sensor 2 , twist throttle and note voltage is going from 5 -> 0 volts.
put meter on blue/brown sensor 1, twist throttle and note voltage is going opposite, 0 -> 5 volts
turn ign switch off.
check for continuity on all 6 wires. from the connector
blk/gray is pin 1 and goes to pin 62 on ecm
violet/yellow is pin 2 and goes to pin 39 on ecm
red/white is pin 3 and goes to pin 68 on ecm
black/white is pin 4 and goes to pin 61 on ecm AND pin 1 on connector behind throttle body backing plate.
blue/brown is pin 5 and goes to pin 59 on ecm
brown/orange is pin 6 and goes to pin 50 on ecm AND pin 5 on connector behind throttle body backing plate.
also check continuity for wires at connector behind backing plate
pin1 ( already checked from above)
pin 2 goes to ecm pin 30
pin 3 goes to ecm pin 29
pin 4 goes to ecm pin 36
pin 5 ( already checked from above)
pin 6 goes to ecm pin 37.
enough for now, let us know what you find.
