BUBBIE
Well-Known Member
This is on the second report from Blackstone:
LONNIE: Another great sample from your Harley! This fill has 6,111 miles on it and wear metals are still
below average. That's impressive, because our averages are based on about 4,200 miles on the oil. Your
engine is wearing better than most. If you ever decided to run the oil longer you could, with the low wear
and strong TBN (4.4 is great). We'd recommend trying 7,500 miles, and if wear stays low, going longer after
that. This oil is holding up well and seems to be a good match for your engine. The viscosity is fine, no
contamination was found, and solids are low at a trace.
Also, saying: SUS Viscosity @ 210*F shows (should be Values 80 - 95) first report shows Value at 89.3 and the 6,111 mile report shows 86.5
All oils lose some of their Viscosity when used. (some oils More and some oils Less)
I see Blackstone was OK with the Viscosity when checking. They said so...
Case Is Closed for me...... it is doing a good job and shows Lower than Normal wear on my 103" motor and their statement that the motor likes the oil too...
Any oil out there showing better?
You are welcome to use it THEN TEST it and see what your report is...
By the way y22c, What is Your favorite oil?
