Hoople Account Removed Aug 5, 2011 #11 Re: Runs lean under load Hate to tell you this, but if you want to get to the bottom of your problem quickly, you need to find a way to check the fuel pump pressure.
B Babe Member Aug 5, 2011 #12 Re: Runs lean under load slightly bigger cams were installed back in 2008,but bike ran fine for a couple years after that.
B Babe Member Aug 5, 2011 #13 Re: Runs lean under load dont understand the new post / original post thing
G glider Veteran Member Aug 5, 2011 #14 Which fuel injection do you have on that bike, Delphi or Morelli? Probably Delphi?
