dolt
Well-Known Member
I would never do 10 heat cycles; two for about a minute each is enough to check for leaks and listen for funny noises. All those heat cycles should be saved for break in process. The break in is the friction developed between the "rough" ring face and cylinder wall ridges in the cross hatch as they mate together. A lot of short heat cycles, IMHO, interferes with that process. After a couple of quick heat cycles to confirm no leaks and motor sounds good, get on the bike and ride. Cycles of 2-4 up to 4000 rpms, decal down (engine brake), rinse and repeat as the motor heats up to operating temps. Rings should seat in the first 25 miles; heat and compression is what seals the rings.
