You already had the bike tuned with a hi-flow intake so you don't need a tune; all you need is a pull to check AFR at idle, partial throttle and WOT. Most dyno operators will to that for $30-$50; a minimum charge for use of the dyno. Of course, if the operator sees that you need an AFR adjustment (most likely at WOT, there might be an additional charge to make that adjustment, otherwise, after a verifying pull, you are done.
A full dyno tune, by a good operator, on an "untuned" motor could easily take 4-8 hours and 20-30 pulls with cool of time between the later pulls. Talk to the tuner and explain your situation and if he/she won't do it for a minimum charge, find another tuner.
New intake looks good BTW.
