oldhippie
Senior Member
I have a Kuryakyn hitch for my Ultra and a Neosho Starlight Juniper trailer Jupiter — Neosho trailers. It's a very light trailer, has LED lighting, swivel hitch and holds all we need for a long trip. Beats overloading the bike and making it top heavy.
The weak point on the trailer is the latching mechanism, though. I've broken 3 of them on 2 trips. Don't know if they've changed the design of that since no one carries their models in my home province. I had to order it in from southern Ontario.
The hitch is fairly easy to install and remove. Had to cut the tab off the mount that holds the air shock valve in place though.
There are wiring harnesses available so you don't have to splice into the bikes wiring. Makes it easy to remove any trace of towing. Here's the one I use: HD Quick Connect Wiring Harness
With LED lighting on the trailer, the extra electrical load is negligible.
All 3 dealers in Manitoba have no problem with honoring the warranty and are fully aware of the corporate H-D stance. One dealer even sells trailers. They all tell me the same thing: How are they going to prove the trailer caused the failure unless it's a rear suspension problem?
