J
Jack Klarich
Guest
Like Bubbie says, on the Sporty, it is the rear top and bottom flange nuts (have to remove the chome shroud to have enough room for thin walled socket to fit. Found nut from the top stud lying in the web of the casting below. Used lock washer and has never been a problem since. Do not use locktite and very light bit of oil to prevent binding. :s
Seems to be a on going problem lately. I have seen alot of these nuts falling off. Like NEWHDFAN I have already replaced my exhaust nuts with grade 5 nuts and lock washers before the stock ones get a chance to loosen up
