The ignition coil will need to be unplugged from the wiring harness at the point where the smaller wires connect to the coil. Once those are un-plugged from the coil, use a ohm-meter to test the primary and secondary windings.
To test the primary windings, connect the ohm-meter to the points on the coil where the wiring harness connected to the coil. The primary resistance should be about 2.5 - 3 ohms.
To test the secondary windings in the coil, put one lead from the ohm-meter to each end of the spark plug wire connections. The secondary winding resistance should be about 10,000- 13,000 ohms. You can check your manual for more specific specs on your coil.
