My sportster is a 93 and is solid mount i have replaced the seat and fitted iso grips and pegs to assist with the vibration
It does have a shorter wheelbase and stiffer suspension than the big twins this coupled with a narrow front wheel makes the sportster a good bike on twisty roads as the handling is fairly quick and direction changes can be made without issue when i tried some of my favourite twisty roads on the softail i found that the setup could not go from a left hand bend to a right hand bend with some bumps in between too much bounce in the suspension
I can do 2 hours on the sportster but longer touring journeys are better on the softail
Different bikes for different uses but the sportster is a fairly good bike at what it is designed for
