Hoople
Account Removed
i set the rpm on my dad's 00 rk just above stalling rpm...
far on my carb tc 04 fxdx, idle 600rpm no leakage.
if idling rpm is too low, what's the worst thing could happen?
Oil Pressure is a function of several variables, one of which is the bearing clearances. No one answer will fit every ones application. If I was doing what your doing with lowing RPM, I would temporarily install a mechanical oil pressure gauge and check what your oil pressure actually is when the engine was hot and the oil was due for a change. You may be in single digit numbers.
