What I do is:
Then I do the whole thing with rotating the engine by hand with the rear wheel followed by turning it over with the starter. As long as no noises, I reinstall the plugs and back it out!!
If you were not at compression TDC, but were at the top of the exhaust stroke, I don't think you would have been able to adjust both of the PRs the full amount and still be able to easily rotate them with your thumb and forefinger. The intake lifter would have been riding up the lobe on the camshaft and I don't think you would have enough collapse on the lifter plunger to allow for it to collapse enough for the PR to turn easily. So as long as that step was followed, I am thinking that you probably did NOT mess up. HOPEFULLY!!!
Cheers,
			- Pull the sparkplugs
- Put the tranny in 5th or 6th gear
- Jack up the rear wheel just off the ground
- Collapse the pushrod covers
- Collapse the pushrods and remove (mark each where it came from)
- Rotate the rear wheel and watch the lifters for: Exhaust open then close, Intake open then closing
- Next time piston is at top of stroke is TDC for that cylinder (use straw in sparkplug hole to feel piston at top of stroke)
- Adjust pushrods
- Walk away for 20-30 minutes
- Check that pushrods turn easily with thumb and forefinger
- Button up pushrod covers
- Repeat for other cylinder
Cheers,
