J
Jack Klarich
Guest
JMHO but I would go to the Blackstone website and request one of their collection kits, which they provide at no cost, catch a sample of oil and send it back for testing.
You won't want to hear what comes next and may choose to ignore but the only way you remove all the metal is to pull the motor and oil tank; anywhere that oil remains in the motor, i.e., lines, passages, piston jets, lifter galley, etc., etc., metal remains as well. The motor needs to be completely disassembled, cases split to insure all the metal has been removed. This will also allow a thorough inspection of the crank, wheels and bearings as well as the balancer assembly. If metal is traveling in the oil, the crank bearings have probably already seen some damage.
You will hear that you can flush the motor with diesel fuel and feel free to try that but be advised that if any metal is left floating around in the motor, you will very likely be tearing it down a second time and tearing it down all the way. It's a crap shoot; your ride and you decide but you pays yo money and you takes yo chances!![]()
Dolt is right on here, no amount of flushing would do much good at this point IMO. The trash in my engine appeared to sand blast the pistons, the piston jets were plugged up, The oil passages from the tank thru the cases would be the hardest to clean, the manual is very specific on these passages, best of luck and keep us informed
