Thanks guys!!!
Dan do you use red Loctite when you switched around?Depending on your risk tolerance, you can flip the axle bolt around and have the nut on the right hand side. MOCO does it the other way just in case you spin that bolt while riding, it will just tighten the nut vs loosening it. I just check it when I do my monthly inspections anyway and have had no issues and now I can pull the rear without needing to take the exhaust off too.
