J
Jack Klarich
Guest
You do not have a backing plate similar to this?
Yes you need a backing plate. The biggest reason is that the backing plate holds the throttle body steady and relieves pressure on the intake seals on each head. The backing plate attaches to each head with those nipples that are sticking out. In addition to holding the throttle body, those nipples are where the crankcase pressures vent out. Look at the photo of the chrome stage1 back plate. Those round black things pop out, then the nipple/bolts go in the holes and into the heads, then the round black plugs push back in and vent the crankcase air/oil particles into the throttle body to be burned.
You can pick up a used twin cam backing plate for cheap on ebay, a few dollars more will get you a stage 1 kit.
That is the correct backing plate, your KN filter will not work with that backing plate, however KN does make a round filter and YES you need that backing plate for a correct install
Sorry for the bad news
