dolt
Well-Known Member
I would encourage a Stage I upgrade, fuel management and good dyno tune and I would replace the OEM head pipe with a catless head pipe like the Rinhart, V&H Power Dual, Fullsac X-pipe or Fuel Moto head pipe. This will add 10TQ/10HP at least, in most cases more.
However, that will not solve your problem which is being at the wrong rpm level to overtake a vehicle. The H-D vtwin motor loves to spin; my old five speed bikes can run 80-85mph 3300-3500 all day long with no issues.
Two up and loaded, you should probably be in fifth gear most of the time instead of sixth. 2500rpm and below is lugging; add a passenger and/or luggage to make things worse. As others have rightly pointed out, down shift to whatever gear gets you in the power band which is between 3000-3500rpms; drop the hammer and move; your motor will thank you.:coffee
