ProF
Junior Member
Lark and others make a good point. Both the Snap-on and the HF socket wrenches will tighten/loosen a bolt. The difference is in the quality of the materials. HF is fine if you use it once a week for an hour. If you use it all day, and your livelihood depends upon having ready-to-tools, you might want to go with the more expensive tool.
Same with a lift. If it has to go up and down several times a day, every day, under all kinds of loads, I'd want the more expensive one. If I had the time to carefully balance the bike, get it just right, and then take it up once, I'd go with the HF.
