krikket
but brake fluid also damages standard seals used (eg nitrile o'rings) and insulation used on electric cables (PVC and PE). If a full reservoir of fluid was lying in amongst the wiring I would be concerned.
washing it down with soap and water would probably be the end of the story. Modern surface treatmens are very good should withstand a 1 off occurance like this (if it was the middle of the tank where even the slightest discolouration would annoy that would be a different case of course).
If there's nothing else wrong, the dealer will just wash the bike and say they didn't find an problems. Being that DOT 4 is hygroscopic (water absorbing) it will brake down seals and wire insulation, but it will take some time. If it's washed off in a timely manner, there probably won't be enough damage to worry about.
And I'm sorry, but leaving all the brake fluid mess on your frame, seals and wiring until the dealer puts all this stuff in writing is purely negligent. That's like calling your insurance company to tell them your house is burning down, but not calling the fire department. Wash it off!!
