Sorry for the slow response, but I'm ready to run the bike off a cliff.
I check the tripple tree and its all good.
I got new front bearings installed and that solved the slight speed wooble.
The front tire could stll give me problems. Only time will tell.
My biggest worry right now is the S&S E Shorty.
1 - Poor idle and back fires thru the carb.
2 - I did check the timing and was able to see the vertical mark thru the plastic inspection screw. Can I assume that my ignition is working properly ?
3- I thought some rust was getting into the carb so I pulled the petcock. WOW was that screen covered in rust. Its clean now but still the same problem.
4 - The plugs were black and I replaced them.
5 - Both spark plug cables were also replaced
6 - The intermediate jet is 295 and the main jet is 74. Thats the recommended size from S&S.
7 - The Fast/Idle plunger sticks.
8 - The Idle mixture screw is damaged and I have no way to detemine if the upper housing is also damaged.
9 - I have already adjusted the float.
10 - I also may have damaged the slit in the Enjector nozzle that is permantley attached to the bottom bowl. The slit is supposed accept a 4 mill gauge which it does now, but when I originally had it, it would only hold a 1mill gauge (DIRT), The spray pattern from the slit is not uniform.
I barely got the engine to run but only at 1500 RPM.
I would like to go back to Harley CV carb but that would invlove more money.
I'm going to order a new S&S E carb.
