You mean like a chatter as you turn the bars? As if you had flat spots or depressions in the bearings? That should not be there.
For about 15 degrees of the turn as the trees are near straight ahead (bout 5 degrees before straight, 10 after) I definitely have this. You don't hear a pronounced chatter, but you can hear an extremely faint low frequency hump hump, but this may be coming from the bike itself flexing on the lift. BUT YOU CAN DEFINITELY FEEL IT. It is VERY pronounced on the FEEL test. The front end seems to bind and jump on each frequency, so much so that just turning my bars through this area actually makes the bike lift roll and inch or so in the direction of turning, by the time I through it. You can visually see the front end bobbing up and down a small amount as it turns thru this sweep.
Dave, if this bike sat outside for a lot of its life and the bearings were never right from the factory ( IT Happens) with the combo of salt air and rain you may have bad bearings. You are this far might as well check them out JMO
The previous owner worked out of town and only rode the bike on weekends. It was parked in a small metal shed all week.
TIRE/TYRE:s
Bubbie are you saying a bad tire in the past (or present) caused this bearing damage ?
. . . . . . if it is the steering head bearing that is a wee bit notchy then it would need replacing as i have never done a steering head bearing on a harley i can not really give any definite advice although previous experience says that the lower bearing can be a bit of a pest to get off the steering stem and plenty of heat will be required. Brian
Yea I've already read what a pain the bottom 'sometimes' can be. In fact some folks have actually pulled the entire lower tree and stem out of the head and then end up having to take it to an Indy to get the bottom bearing off. Course I don't know what kind of special tool they have? I see visions in my mind of paying for them to cut and beat the thing off just like I can do (with possible damage to stem). I do have a heat gun though, if it ain't frozen on.
Well this is just special. I feel about as happy as a cow at the slaughter house. This is just one of a long list of things that have broke in my life over the past 3 months. Couple that with loaning some money to family and friends to help them, then blowing the rest on my new TBars and Dakota Speedo and I am just about give out with all this. To make matters worse I came in last night and found my small frig in the utility room was broke and all my beer was hot.
I think I may just park the bike for awhile and concentrate on putting some new gaskets on my truck and just kinda re-evaluate a few things. I can still put ice on the beer. I had a horse once when I was a teenager, it was expensive to maintain also.
