Some ideas on what I changed for the same situation.
1) Save the map that they installed on your laptop. you paid good money for it and you do not want to loose it.
2) Copy that map with a new name then....
3) assuming your VE tables are calibrated properly (and they should have after the dyno) drop your AFR table in the 20 MAP collum (farthest left) from 4K down to 1250K. I dropped mine down to 13.8. This should help the decel pop when you have the throttle closed (not turning it) and the engine is braking.
4) go into your decel eleanment table (this adjusts the volume of fuel when closing the throttle (i.e. when you shift) and either increase it (reduces the fuel when closing) or drop it (increases fuel when closing). I decreased mine slowly until it stopped.
5) What is your AFR map look like? I've noticed if your idleing at 14.6, and you take off, the exhaust is so hot it ignites in 1 to 2nd gear shift (pops). I'm only running closed loop for my cruise range (1250 to 3000 from 30-70 MAP). Still getting solid 42 mpg.
6) I also changed timing to what the canned map was from the SEPST program and that helped, but the dyno guy should have adjusted timing as well as all other aspects of the map when your bike was dynoed.
Hope this helps...
