iamdent
I finished changing my 06 to hydraulic tensioners last night, I installed the new hydraulic tensioner plate and upgraded to 204 cams. Used Se adjustable pushrods and installed new lifters. I had an Indy press the cams into the plate and install the in cam chain. Everything went together great, but when I try to start I get no run. It never even acts like it wants to fire. I have checked the CKP per the manual, checked and installed new plugs, checked the battery charge, disconnected the Dolbeck tuner so as to start on stock EFI settings. I ran a compression check and have 120 psi on the front cylinder and 122 psi on the rear. Engine turns over great, smooth, no funny rattling, clicking, banging, nothing. It just won't run. Any suggestions?
