Safehaven
Drill the holes for the internal wiring wide enough. WIDE enough..
It's a mess to find out half way through your mounting operation that they just won't fit..
Also, when you drill the holes, don't drill perpendicular to the tubing, but at an angle so the hole follows the direction of the cable passing though, then thoroughly deburr until you have butter smooth edges.
Your cables will thank you for it in the long run.
Take care and good luck!
