Anthony mills
Hi all, I have a 2016 SGS, I had on dash where neutral lite was on all the time, could not see what gear was in. Did some search and replaced neutral switch. It went out quickly...found out I have a code B2218 which is neutral switch shorted low. I truly have no idea where to start here and have not found anything on web . I have went through all the connections points and found nothing loose nor pins loose in connectors. The second new one went out as soon as I took for test ride.
