free website stats program New camper | Page 3 | Harley Davidson Forums
New camper
Moog Front & Rear Coil Springs
Moog offers two types of coil springs: constant-rate springs that restore handling to its original state, and cargo-coil, variable-rate springs as an upgrade for vehicles that carry heavy loads.
Moog constant-rate springs are built to replace original equipment springs, returning ride height and body sway to original performance levels. Replacing worn coil springs with Moog constant-rate springs restores vehicle handling.
Moog cargo-coil, variable-rate springs change resistance as they compress and become progressively stiffer as the load increases. These springs are vinyl-coated for corrosion resistance and extended service life.
Moog provides several features and benefits on both Moog constant-rate springs and Moog cargo-coil, variable-rate /makemodelsearch.cfm?Id=32springs.
On both, Moog heat-treats the alloy steel to ensure the coils rebound fully and resist sagging. Moog also provide constant-rate springs with an enamel coating that resists corrosion and extends service life.
While many coil springs are equipped with protective tubes to insulate the clash of metal on metal, Moog uses a premium urethane tube that will outlast our competitors’ PVC tubes on both our constant-rate and variable-rate coil springs.
Have a look here Mark, We had good luck with these springs for towing packages:s
Thanx, Jack. I'll check'em out.
