BUBBIE
Well-Known Member
i tryed Bubbie's method and it works every time after the bike is warmed up. mine still klunks the firts time you put it in gear
I also find that the first time is the toughest one.. The oil and all the clutch plates are their most stubborn at this time.. IF your clutch IS not More than a 1/2 turn out at the main adjuster clutch pack and the cable IS adjusted tight also at 1/16 inch COLD.. It should stop Even when cold,,,, OR it does on my rides....
Now my 09 has the slightest clunk after warmed and very slight at that...
The noise of shifting thru the gears is there for me also but it isn't a Bad sound it is just Big heavy (smooth) noises that are a part of HD life style... Look at a gear set some time In real life..... Massive and heavy-duty... Beautiful to say the least...
