flipper
Account Removed
Flipper,
Your air shocks in the rear might need adjusting. The owners manual gives proper PSI for your year and model. My 2008 is the old frame so I won't tell you my range as it will be different.
Here is a link to some info on the adjusting of the shocks on the touring bikes.
Harley Davidson Forums
The valve to add air is behind the left saddlebag. As mentioned in the tip use a hand pump to adjust proper pressure. Don't use a tire compressor.
Thanks for that great info Tank. I thought the bike might just be a little stiff from being new since they hadn't touched it after it arrived at the dealership. Either I'm getting used to it, or it is in fact loosening up some. I should have the first 1000 miles on it next week, so I will see how it performs then. The shocks may still need some adjustment.
