karlsbike
Fin
I was worried when I saw it. To be honest, I did not give the fender clearance much thought when I looked at clearances as I was mostly (only) considering the belt and swingarm set-up...
As I was doing a total re-build this winter, I have everything routed on the LH side.
Now here is a bit of interesting info - not sure if all Harleys are the same, but all tourers (that I've looked at) are set up like this:
The rear wheel is sitting offset to the right, giving a larger gap on the LH side of the fender. Not sure if it is offset relative to the front wheel or only to the fender, but I will check.
The tank is also sitting offset to the right, giving a larger gap on the RH side. The net result is that the front wiring harness is routed on the RH side under the tank, while for the rear end it is routed on the LH side.
